Technical  Multipla stereo
kev the kitchen
Bristol
Hi all
I was woundering if anyone knows were I can get an audio instruction book for my multi its the one with the cd changer
the problem is when i try to change radio frequances i get lots of words keep coming up (sport, classic, style,) ect and i cant seem to get rid of it
this is the problem with the seat in the middle my daughter ccnt leav the buttons alone.
Please can anyone Help.:confused:
Hello
First post on this forum (still busy reading everything!) so hello everyone.
I can't post links on here yet (apparently I need to log five posts before I can do that) but if you go to the other Multipla forum - look for nickhostwith.me.uk on a google search for Multipla owners club, then go to the 'stuff' page - there's a manual for the Blaupunkt stereo and CD changer (it is the same unit as the manual, just with a Fiat cladding on the front) to download.
Hope this helps!
Hi,Does anyone know where I can get the pointy things which remove the cd player:DMy one year old son has just put some coins in the cd player(n)Hoping they will shake out if I can remove the cd player.Thanks Simon
Hi Simon. I got mine out using two small electrical screwdrivers. Cheap option :) Hope it works for you. Chris
If you try the coat hanger trick, you may need to file two little v's on the end of the wire, then round it down to a blunt point.
from the end of the pointed end to the little v's is about 1/2".
you should end up with a two prong fork - the forks about 1.1/4" apart.
you'll need a pair of course.
hope this helps
George
