Technical multipla fuse 12
dogflap
Hi guys could really use some help, her indoors has just brought a 52 multipla 100 with no working interior lights or stereo. so i thought i would look into it and found fuse 12 to be missing. replaced it with a new 10amp fuse, the lights and stereo worked but both front hazards then started flashing and wouldn't stop.have taken the fuse back out now and am at a loss what to do.
thanks for any advice in advance
cheers
dan
Well, a stab in the dark would be a faulty hazard switch. I presume the hazards don't work when the fuse is out, which would explain why some lowlife has removed it. The switch comes as part of the complete panel.
no thats the odd thing the hazards work fine even with the fuse out as they work on fuse 13 with the indicators
quick update as still really need your guys help. it looks like its the anti theft lights which is odd as the car starts fine.
the key is a bit battered and the battery is quite rusty and the fella only had the one, so not sure where to go from hear any advice would be great thanks in advance
yeah it seems the guy we have brought it off has disconnected the siren as the key is pretty messy but has left the alarm functioning as when you insert the key the hazards/indicators flash for thirty seconds so i am thinking if i disconnect the alarm box it may help but have no idea where it is
Hi all i have finally located the alarm box but the two plugs seem really tricky to remove ( being a alarm i suppose that makes sense ).Has anyone else removed these plugs or does anyone know if or where the catches are as its getting real tricky with no blowers as its getting colder now.
thanks in advance
