you wont be able to just plug and play if you want the car to work as it should do. eg turn key, code lamp out, car starts etc.
however if you can borrow an ecu from someone for diag purposes then you could use the emergency start up procedure to bypass the immobilizer system.
pretty sure multiplas have this.
