- Joined
- Sep 14, 2009
- Messages
- 19,849
- Points
- 3,390
This little booger is a joy to drive but it's fighting me all the way. Performance is good engine runs smooth and its sipping fuel.
However, it's using coolant. There is no smell of coolant in the exhaust, no smell of exhaust in the coolant oil is clean and oil level is constant. Worryingly, there are no drips anywhere and the level drops pretty fast when driving though not when left idling. I have just tried some radiator leak sealer just in case it's a small leak that closes up when engine is off. The level is still dropping. Please dont confuse it with that risky rubbish which alleges to fix head gaskets.
I'm about to order a compression tester but it's probably a white elephant as the engine runs so smoothly.
Question 1 - Are there any known coolant leak points on this engine that I should be looking at before the compression tester arrives?
Question 2 - Do HC in coolant (colour change) chemical tests work on diesels?
Question 3 - How do you test for EGR cooler leak?
