Evening guys, bit of a long one. I've got an issue with an ABS warning light on my dash that has been niggling me for a while so any help will be appreciated.
It appeared a few months ago after starting my car to go home from work, it was fine a few hours before when I went out for lunch.
I downloaded multi ecu scan (1.3 at the time) which only showed an error of "open circuit short circuit at +V batt" in simulation mode which isn't very helpful.
A month or so after that the platts fiat garage put it on their system and noted that it was the o/s/f abs sensor that needed replacing so I finally got around to buying one and fitted it earlier.
I've downloaded multi ecu scan 1.6 and hooked it up again using the correct cables etc. Here is what happend below when I connect (scan).
1 - EBD faliure appears on dash and then disappears (this does not appear normally when starting the car)
2- ABS light clears for 2-3 seconds then reappears with the warning
3 - The multiecuscan window displays an "invalid ISO code" message
4 - I mutter some obscenities and we're back to square one.
Worth noting that it still says "open circuit short circuit at +V batt" in simulation.
Like I said, any help will be appreciated before I take it to fiat to have a look at. Cheers, Josh.
