gengis
Hi Troops,
I’m looking for a bit of advice/help in diagnosing a fault on the wife’s 500x 1.4T Multiair 2016 40,000 miles. It all started to misbehave a couple of weeks ago, the fault presents itself on a cold start and sounds and feels like it’s running on three cylinders also brings up a standing engine lamp. After it’s been idling for a few minutes and a couple of increments on the temp: gauge are showing… if I turn off then restart, the car runs perfectly all day with the engine lamp sometimes extinguishing …until another stone cold start.
Now…I’m a bit of a home mechanic, but a bit of a dinosaur having a couple of 124 Spiders and a 128 I belong to the analogue world of motoring. Suppose I’ve been lucky up till now! I have now bought a code reader…see below the codes been transmitted, the last code I have only captured intermittently.
The fault conditions have not changed, although the engine runs smoother. This is where I am now…Do I have a misfire (ignition fault) or MultiAir unit fault. Could the ECU be sending corrupt signals to coil pack or actuator or both?
Any help deciphering my fault would be appreciated.
- P0304 - misfire cylinder 4 (performance or incorrect operation component or system over temperature, misfire 1000)
- P0300 - misfire random (performance or incorrect operation component or system over temperature, misfire 1000 or misfire 200)
- P0130A - misfire 200 (component or system over temperature)
- P106B – cylinder 4 UniAir actuation electro-valve signal (Actuator stuck open)
