Technical  Moving steering
Drinu
Established member
Hi guys,
when I lift up my steering wheel or push it down there is a slight movement. This becomes annoying on less than perfect roads! Is this normal??
No.
My bet is on the nut where the steering rod connects to the other piece via clamp - easier to look and see than to describe :eek:
If memory serves right, it is for 13 mm spanner. Tightening the nut should get rid of the free play.
the u/jiont is proberly worn where it connects to the rack.you need to get someone to inspect it whilst column moved up and down. easy to sort! (y)
