Technical MOT failure
briar
could someone please tell me where the brake load sensing valve linkage is please as I don't have a clue
Thanks.
its attatched just above the back axle i changed one of these recently its a c***!!!!!!!! and the part was expensive too.
what make and model of tipo do you have????
best bet would be to phone around motor factors in your area and look for it on net. try gettin a good price though!!
dont know if you can take the valve out and make 't' piece maybe sumplug or sedicirich or daz would know
Think you find the Tipo 1.4 will not have a proportion valve due to rear drums.
What is the matter with the rear brakes??
Andy.:)
This is what I dont understand the bloke passed the brakes but failed it on this load valve thing.
No, He cannot fail it on the load valve. It is not part of the test. He only measures the efficiency of the handbrake and foot brake on all 4 wheels.
Either the handbrake is not working efficiently enough, or more likely the rear Foot brake efficiency is below 50%.
Sounds like the rear drum brakes need inspecting, stripping down, cleaning, self adjusters freeing off and resetting, and if needed, new brake shoes.
Andy.:)
the failure says
Brake load sensing valve linkage seized.
when I asked about it he said I needed a new one.
