MOT Fail - Emissions Help
H
HicksonUk
Just had my MOT and it failed absolutly gutted lol, sencond year in a row its failed.
Headlamp insecure
O/S/R Wheel Bearing
Emissions - This is where i need the help. Heres the results>
Temp Pass.
FAST IDLE TEST FAIL
rpm pass 2720 limit 2500-3000
CO FAIL! 1.81% limit 0.30 MAX
hc pass 99pm limiy 200 max
lamba pass 0.98 limit 0.97-1.03
SECOND FAST IDLE TEST FAIL
rpm pass 2690 limit 2500-3000
CO FAIL! 1.15% limit 0.30 MAX
hc pass 83pm limiy 200 max
lamba pass 0.97 limit 0.97-1.03
natural idle test pass
rpm pass 830 limit 450-1500
co pass 0.21% limit 0.50 max
My cars a Fiat Bravo 1.4s 12v 1998
P.S It failed last year on emissions was alot worse but had the CAT replaced apparently lol.
Any help appriciated
HicksonUK
Well, the cat is working, thats for sure.
When did it last have the air filter changed?
A year ago few days before my last MOT, thing is ive used it for about 11 months and ive been using a pipercross air filter changed it back to original one though for MOT, do you reckon that this could have anything to do with it?
glad its not my CAT.
Thanks by the way.
Could be, or you're burning oil.
I'm sure someone will say 'its the lambda' as they always do.
What about spark plugs and leads? How old are they?
leads could be 2 years plus got them with the car and the plugs around 13 months old Bosch Super 4's, so you reckon i should give it a little service?
Oil
Plugs
Filter
HT Leads
HicksonUK
Oil, plugs, air and oil filters.
And give it a good thrash.
emissions
good advice from Tom there, run it on motorway as fast as you can get away with, also if fuel tank is nearly empty ,put some aditive in
Get half a tank of super unleaded, stick a bit of additive in there, and drive everywhere in 2nd gear on the way to the MOT station.
SEX...I'm just two women short of a Threesome
Thanks for all the help guys, so what we going with then? All these?
Filters
Oil
Plugs
Super Unleaded/Addative then 2nd gear
Good thrash on motorway
Alot for a sunday for me any way lol.
Thanks again for all the help
HicksonUK
take it out thrash the life out of it for 30 mins then get the emissions done
So would it be wise to still change everything im on a really low budget at the minute lol.
Thanks HicksonUK
Yes cos they will be worn out. All that lot will cost less than a tank of fuel.
Filters - air and oil - £10
Oil - £20
Plugs - £15
Ok thanks going to get parts now would it be wise to leave pipercross on for MOT?
HicksonUK
Use the pipercross only if you clean it.
Selenia 20k is my oil of choice but any semi synth 10W40 will do.
ok cheers ill just get a standard one and keep it on for MOTs
Thanks for all the help guys ill let you know how it goes fingers crossed, aint booked re-test yet though lol.
What litre oil should i buy? to do oil change?
7K
David Slaney
L
11
477
Dark Lurker
G
10
496
Tommy K
T
