More Questions!
More Questions!
T
Tabletto
Hi again, I know this is my second post lol
But I always forget what I wanted to ask...
I have a MK1 Bravo, the wing mirrors are black plastic, not body coloured. A slight part has cracked and has gone white with water etc...
What can I do to fix this, any sprays....sealents?
Also...I have 17 inch TSW Razor Alloys with Yokohoma Tyres.
Im not sure what psi I should have them at....becos the manual is for standard tyres. Or should it be the same psi for the Bravo?
If so what is the recommended for the Fiat Bravo?
Once that plastic has gone shitty you either live with it or bin it. I tried cleaning mine and it looked worse.
You can spray paint it BUT you really need to prepare the surface very very very well otherwise it just peels off again. Best left to a spray shop, its cheaper in the long run.
This a common prob on the Bravo and mines the same. Use the search as there are many ideas already posted here mate.
Shabash!
Re: Re: More Questions!
I bought new mirror mounts for my marea from a scrappy. cost £50 cause I had to buy the whole mirror assembly.
Is it the mirror casing or the mount?
If it is the mount (triangle piece inset in door) this is made of an alloy, the white being a kind of corrosion caused by oxidisation. There is another post on this subject where someone suggests (I think) Hammerite type paint.
Mark.
B
2
532
BRUNO
B
4
496
Darren
