Tuning  Month to madness
Liquid Knight
Distinguished member
So I recently sold my Punto GT, bought a Punto TD, tarted it up with spare GT parts and sold that. I took this 899cc Cinquecento as a part exchange.
Yes it's on the bump stops, yes it was fun for the first mile and yes it's bloody dangerous.
Anyway driving on the bump stops reminded me of my old Mini and got me thinking. There isn't a Mini any more. :(
BL Mini's are too expensive. BMW ones are either crap or overpriced crap.
Where are all the cheerful little cars that are cheap and easy to get hold of, easy to modify or upgrade from the parts bin and still utilitarian?
The Cinquecento is probably one of the best of the bunch. 899cc so cheap to insure, Sporting parts bin upgrades and more from the family tree. Can be picked up from £50 to £300 on the road and tunable. There are a couple of t-jet Cinquecento and Seicento projects terrorising exotica. Obviously there are more options like the VW Lupo but you have VAG insurance and the pretentious Dub Scene to deal with. Suzuki Alto are a pain to find parts, Ignis is too new, Swift too big. Citroën C 1,2,3 are all terrible compared to the old Saxo but good luck finding a decent base model one of those and the pandemic of VTR/VTS/V6 powered Saxo's that are "Still 1.1 on da log book innit bruv" should all com with a free barge pole. 107's are coffins, CityRover's can't handle the power they have let alone tuning or transplants. That's just about it.
Don't get me wrong for a rushed job the BMW MINI isn't all that bad. It weighed more than the Neon 1.6 engine could handle, as big as an Astra outside but smaller than a Corsa inside, poorly engineered but a good marketing exercise. Apart from that it was a welcome alternative to hum drum euroboxes of the period and gave the "it" crowd something that wasn't French to break down in.
Now you can get a BMW MINI for a lot less than a real Mini it almost makes sense but any bargain BMW is potentially a bottomless pit and the MINI is no exception to that rule.
So if this Cinquecento is going to a homage to what the Mini used to be it will have to stay 899cc for now.
You can almost feel the Pooooooowwwwwweeeeerrrr!
...wer
...wer
...wer
Okay the boot isn't that big. ;)
These...
...will have to go for a start.
So what's the plan?
Two of my nephews are seventeen next year so I'm going to get them involved and show them a few tricks I've learned over the years. ;)
There are a few repairs one would expect from a twenty two year old Fiat, sort the suspension, buckets, harnesses and cage.
All in time for a charity track day November 18th (if I can get the time off work) and auctioned of for the same charity just in time for Christmas.
I'm keeping the 899cc engine standard as just like a Mini you do all the other upgrades first and then make it go quicker. :D
If the car doesn't sell I have a 1242cc Punto 60S and 75 (866) cam' in my shed for a potential (sort of stage one) transplant later.
Keeping it simple. No sunroof, electric windows or central locking ballast so if I can lose the weight of the cage (roughly 40Kg) the car shouldn't loose any of it's blistering performance. :D
I've found that with solid discs but the theory is drilled and groovy ones should dissipate heat better.
No nephews today one has a chest infection and the other is at his girlfriends. Meh, he'll soon find out cars are more reliable, fun and cheaper. :p
Also no parts as yet so I raided my shed and found the bonnet pins from the N/A Coupe 16V and pin cups I bought for Guff II.
1/ Open the bonnet and remove the sound proofing membrane.
2/ Now remove the rubber bonnet stops.
3/ Use the bungholes to test fit the pins.
4/ Mark where the pins touch the bonnet and drill some pilot holes.
5/ Cut the pins to length...
...refit...
...and make sure they do not interfere with the headlights.
6/ Take a hole cutter and use the pilot hole as a guide for the pin hole and draw around the rear of the cup for the other hole.
7/ Cut between the holes with a grinder and place the cup in the hole. Make sure the edges are clean and not sharp with a flap wheel.
8/ Drill and pop-rivet the cup in place and pop-rivet the pin from underneath.
9/ Do the same the other side and you're finished.
10/ The bonnet liner, opening mechanism and steel you have cut away makes roughly 750g...
...and the pins and cups weigh 150g so that's a saving of 600g. Cinquecento Superleggera. ;)
Ah the 899 with no springs from Northampton, glad somebody saved it!
Saved? Have you seen what I have planned? Wooooo-ha-ha-ha-ha-haaaaaa! :devil:
In the mean time. The brake discs have arrived and after making silly noises about how small they are (seriously the last set I fitted to a track car were 356mm these are 240's) I thought there's no point fitting them until the pads arrive so...
...classic "License to Ill" tour t'shirt, some chain from my engine hoist and I'm ready to party. :slayer:
[ame="https://youtu.be/WsV4eaYqhxQ"]https://youtu.be/WsV4eaYqhxQ[/ame]
A quick guide clip for my nephews as they missed out helping with it. :)
I'll try to keep them all as short. :)
I missed out on the tyres thanks to an eBay cheat app'. I was the only bidder on a st of XR2 pepper pot wheels with nearly new Yokohama tyres. Due to the lack of activity I only bid £70 (and was willing to go to £100 because I know a chap restoring an XR2 and is looking for a decent set of wheels) and was outbid with half a second to go by some cheating, thieving, twuntface! :bang:
That's it no more bidding for me. Buy it now only.
No brake pads yet so more weight shaving today.
Take the number plate off.
Open the bonnet and locate the 8mm nut holding the badge on.
Once removed use an old ice scraper to get rid of as much of the double sided tape as possible and wipe with a cloth soaked in thinners. Select a hole cutter that can fit inside the crevice where the badge was.
Use the hole cutter to make eight holes in the number plate recess taking care not to drill into the radiator.
Take one of the disc you have cut out of the bumper, trim it to fit where the badge was and stick it in place with double sided tape.
Next take a number plate sheet and letters making sure the spacing is all legal. Half inch between the first letter and number, an inch and a half between the number and next letter and half an inch between the final letters. Mount this on the lip of the bonnet and you're done.
The number plate, screws, badge, nut and plastic cut away from the bumper were 410g. The number plate sheet was 15g with the backing paper so 400g saved.
That's the first Kilo. :slayer:
replace tow hook for one of them scene fabric straps, few grams there..
Not a bad idea. :)
I might be painting the bumpers white and putting some kind of stripe to cover where the pop-rivet gun skipped and messed the paint up on the bonnet. :devil:
Martini Racing or Italian flag stripes?
