Just read this, I realize I'm quite late in answering but I'm happy to share my experience by writing a quick summary of our adventure; I’ll also start a thread on here as a sort of guide for anyone that wants or dreams about venturing on this trip.
I have taken part in the latest edition of the Mongol Rally (2019), and incredibly managed to complete the event and also drive the car all the way back home.
Our weapon of choice was a MK1 Uno from 1985; points ignition, carburettor, no ecu and manual fuel pump.. but at least it was a comfy 5 door ! picked it up for €700 from the original owners granddaughter after it had been sitting for the best part of 10 years;
I did all the basic maintenance jobs that any car enthusiast would do to an unknown vehicle (timing belt, w/pump, gaskets and filters..) and made it roadworthy for not much money.
After two years of tinkering with the car and some summertime “test runs”, a team was formed in Sep. 2018, and by April 2019 the car was ready to travel up north towards the UK for the final bit or rally prep until the start of the event in July down in Czech.
We had planned to drive the famous but tortuous “southern route” via Iran and the “Stans”, and were hoping to have enough time (and enough car!) to drive all the way back after completing the event.
We incredibly managed to stick to these plans, driving for 44 days and covering 11k miles, reaching the finish line in Siberia in the last day of August.
The event was finished, but not our adventure, so after a day of patching holes and throwing spanners at the car, we packed up and headed back west towards Italy.
A total of 54 days, almost exactly 20k miles, countless breakdowns and a variety of little faults that were thankfully never terminal, all stuff that can be fixed with a bit of patience and some basic knowledge of old cars.
Most of my problems derived from bad quality fuels: depending on what route you'll chose expect to encounter the crappy stuff from Iran, Turkmenistan or Kazakhstan, where the average selling petrol is 92 octane, but most times the best you can find is 80. Also these are not RON ratings, so fuel can be even crappier than what the label suggests.
For normal cars this isn't much of an issue since they all have electronic fuel injection and variable ignition timing; in my carbureted old bucket of bolts I had none of that, and so had to get the tool kit out where most modern cars would just self adjust.
Must have N.1:
make up a sump guard. make it as strong as you can and don't forget to put some holes in it for ventilation so the hot air from the engine can find its way out. I made mine out of 4mm thick steel. It weighted almost 25kg but was well worth it, I had to bash it back into shape at least twice during the trip, absolute life saver.
being the 169 panda quite a popular car It would not surprise me if you could find an off-the-shelf part for this purpose. I'd also suggest some sort of protection for the fuel tank, I also made this one myself.
N.2:
suspension: as you mentioned this department takes a lot of abuse on this event, and I can sure confirm that. Again, the 169 panda, specially the 4x4, has a good aftermarket support so I'm sure you'll find something.
This wasn't the case for my Uno, and so the best solution for me was to fit new good shocks all round, I’d suggest a well known brand here (mines were Monroe), and the coil springs from the Turbo Diesel version that had a 1.4 liter all iron engine with turbo and intercooler to support. If yours is a 4x4 I think aftermarket is your best bet. For a 2wd car try to find the springs for the Natural Power version. Do not fit spring spacers.
Regardless on whether you'll be 1, 2 or even 4 people like us, the rear of the car will have an awful lot more weight to deal with, this is quite common for Mongol rally cars, broken rear springs even after only 5k miles are the norm.
to avoid this I went for helper springs, or towing springs whatever you want to call them. Much better than the old tennis ball trick, they are small springs that fit inside the rear coils and effectively help them support the weight, they are designed for cars that tow caravans. I was able to find a set on Italian Ebay for my Uno, and they were one of the best improvements in my opinion, the rear squat was minimum, leaving loads os suspension travel left, and we never suffered from broken coils or shocks for the whole length of the rally, and boy were we loaded !!
Have a good look at your steering components and bring 1 inner and 1 outer tie rod. I rebuilt my steering rack right after buying the car and my aftermarket inner tie rods started failing in Uzbekistan. This was a big worry as the roads only get worse from there. Luckily we managed to do enough bodging to make it last the whole trip, but I regret skimping on spares on this one.
I’d do new wheel bearings too for what they cost, the roads are crap and the car will be massively overloaded.
N.3:
Go with a petrol car. Diesel just isn’t as readily available in the far east regions and when it is it’s usually agricultural red diesel for heavy machinery and tractors, stuff that will kill any small common rail European car.
The only diesel vehicles you’ll encounter along the way are lorries, (worth checking out the big Macks still working hard in Iran) and Land Cruisers; small passenger diesels are almost non existent.
As said before, petrol is usually 92 octane. If you’re lucky there’s 95, but I’d say that 80 octane is the most common fuel out there. From Turkmenistan onwards you’ll find that most cars don’t even run on petrol but on LPG, in Uzbekistan that makes more than 80% of the vehicles. Mongolia and the Siberian part of Russia also like a good LPG car.
Also another word of advice: be sure your head gasket is happy, if not, replace it and bring a spare kit with you, and don’t forget the bolts. I met many people with Fiats, and in particular had three friends with Pandas, one old and 2 newer 169 ones like yours, they all had head gasket failures, and for one of them that meant game over. This isn’t to say that any Fire engine will have head gasket failures but they are known for being weak in that department and temperatures at that time of year can reach 40+ degrees; so if I were you, I’d put good fresh coolant in it (bring some concentrated as spare) and make sure your heater works as you’ll be using it loads, it’s a life saver when you’re trying to climb an endless hill in 2nd gear in the middle of Asia in august. A good radiator health check is also a good idea, I went for a new Valeo unit, worked a treat.
Change the oil the day before you plan on leaving, stick to the factory recommended stuff and bring a spare filter with you; if you’re planning on driving back that will be at least 15k miles on rough conditions so I’d do an oil change for the return journey; I did it and it was good peace of mind. Oil is readily available anywhere you go, I had to bring a spare can since my car was on 20W50, not as common as 10 or 5w40, and also because my engine is a 35 year old survivor, and likes a drink.
Exhaust: if the hangers and clamps are not healthy it will fall off, it’s just a matter of time. So be prepared.
Wheels and tyres:
I’d fit new tyres, of as good of a brand as you can find, and bring 1 max 2 spares, no more. I went with some Firestone Multihawk 2 which were the poshest option in my weird size (155/70R13) and it’s just a normal cheap shopping trolley tyre, made in the same factory as Bridgestones just a couple of miles out of Rome. I had 2 punctures, 1 on which my fault (handbrake turn on a gravel road in KZ), and so was able to repair both and drive the whole of the rally (plus 5k miles of testing before that) without any major issues.
No point in fitting off road tyres in my opinion, your choice if you want to go that way; the only thing they do really good is protect you from punctures, but they are otherwise very heavy, noisy and almost scary on the wet or when you have to stop in a hurry.
You are more at risk of getting a puncture if you’re running low on tread, hence the reason to go with a new set. Also get the car aligned ideally once is loaded and ready to go, crucial bit this. Pointless fitting new tyres with the car out of alignment, they’ll be gone in Turkey.
Another important thing is to remember to rotate tyres around, that will help them last longer. Mines are still good for at least another 10k miles after driving halfway across the world.
Rims: I went against everything people say and consciously fitted alloy wheels on the car, and those also made it all the way. I had 2 steel wheels as spares, but my strategy was just to look out for big potholes and I was lucky enough to be able to avoid the worst ones.
Those little MSWs are strong !
With that we come to lighting: most people fit spotlights purely for looks, but if you’ll be on a tight schedule like me you’ll be very likely driving at night for many hours, and so a good set of spotties are a good idea. Don’t fit them on the roof, that will just light up the whole bonnet right in your face when you’re trying to achieve miles in the nighttime, not a good idea. Instead, go for the front bumper. I was able to find a genuine accessory front grille from back in the day, with integrated spot lights. To that I added an SX front bumper with fog lights and upgraded the standard lights to H4 and fitted relays and fancy bulbs to all 3 circuits for more reliability. Bear in mind that in places like Mongolia cattle and camels love to cross the road at night, and if you’re trying to make up some time by speeding up a bit without some sort of high power lights, it will be too late to brake.
I had two close calls, pretty scary experience.
I had friends with only their standard lights, but their top speed was 50, when I could to 70 most times, quite a difference in stopping distance.
As we’re talking about the electrical system I think a new battery is a no brainer. Try to source a replacement voltage regulator for your alternator, those can fail with all the dust, and they’re much lighter and smaller to carry than a complete spare unit. Leave alone the starter motor if it’s working, and if it fails get out and push, not the end of the world (I had to do it for 4 countries !).
Gearbox and bits: changing or not the clutch is your call, only you know your car. Like the suspension this is a component that will be overloaded for most of the trip, and considering the biblical distance to cover it’s worth getting in there to evaluate whether it’s worth changing it or not. My car got there and back with the original clutch, loaded up to the roof and with 4 people on board. We drove the famous Ak-Baital pass in Tajikistan at 4655 meters, and 3 other mountain ranges, no problem. Knowing that this could have been a point of failure I bought a spare with me and I was prepared to change it whenever.
Driveshafts: another component that will suffer badly, and also one for which parts will be mostly unavailable; so pop both shafts out, new grease, new boots and clamps and live happy.
Gear linkage: this varies from car to car, have a good look at the condition of yours as this is one of those weird things to fix if it goes wrong. No problems with cables.
With this we come to the spares to carry, quite an important bit this.
You don’t want to overpack as you still need room for your bags and camping gear, but at the same time you don’t want to be stranded somewhere without that part that you knew you had but decided to leave under your bed.
It’s a fine line really, I decided to give priority to suspension stuff, since I knew from the start that we’d be very heavy, and so took front and rear springs plus 2 shocks. 2 top mounts and one front and rear wheel bearing. I’d suggest to bring an extra air and oil filter (clean the air filter daily as you check oil and water) and a fuel filter if you have it. Spark plugs also a good idea, and don’t forget at least 1 fire extinguisher. Top and bottom rad hose, maybe a thermostat.
For tools I bought my basic 50 piece kit plus screwdrivers and pliers. 1 club hammer (the tool I recommend the most) and a bottle jack (the smallest of jacks) plus some wood. I went overkill with a torque wrench expecting my car to do its head gasket, luckly it never did !
So in essence, try to be sensible, but use your brain as a car enthusiast, to figure out what it’s worth taking and what’s not, I know it seems obvious, but priority vary from car to car.
This “being a car enthusiast” thing is an important point: most teams don’t do a single thing out of everything I have listed, not one. And some of them get to the end without ever changing a tyre or a light bulb. The spirit of this event encourages participants to just pack up some drinks and go; the more the car will break down the more locals you’ll meet, that was the point of the original 2004 edition, and I have massive respect for whoever follows this unwritten guideline.
I tried to find the balance between my mechanical sympathy for an old vehicle that has to cross half of the world mostly off road, but still trying to comply to the rule I just wrote about, simple as that; and even after all my work my car still very much looked like a dusty old Fiat, and during the rally it broke down at least 20 times and had to be taken to local workshops twice; 20k miles on rough roads will take their toll on any car.
As said before, the most used tool was a hammer, and the rest was a whole lot of wd40 and carb cleaner.
I’d personally stick to the original guideline of going with a 2wd car, it’s a lot more “Mongol Rally” than a 4x4, that’s for sure.
I’ll start a thread soon describing our journey day by day, for whoever likes this sort of things.
