I was going to update the first post of my original thread, but can't figure out how to edit it (probably just being dim).
So I'll start again, but won't post individual links as they obviously become dead once the listings end. Everything that doesn't sell gets re-listed, until its all gone!
At the moment on eBay I have:
-Towbar (complete) - £44.99
-Rear Coil Spring x2 (only done 200 miles) - £39.99
-Rear Shock x2 (only done 200 miles) - £34.99
-OSF Wishbone (only done 200 miles) - £19.99
-NSF Wishbone (only done 200 miles) - £19.99
-OSF Wishbone (for re-con) - £5.99
-NSF Wishbone (for re-con) - £5.99
-Front Strut Mount Kit (BRAND NEW & Boxed) - £21.99
-OSF Drive-shaft & CV Joint - £19.99
-NSF Drive-shaft & CV Joint - £19.99
-OSF Headlamp - £19.99
-NSF Headlamp - £19.99
-OSF Indicator - £4.99
-NSF Indicator - £4.99
-Windscreen Scuttle Trim - £3.99
-Air Intake Silencer Box - £2.49
-Washer Bottle with Both Pumps - £9.99
-Rear 2-Point (lap) Belt - £7.49
-Rear Seat Belt Clasp - £6.99
-Rear Seat Belt Clasp (slightly damaged) - £4.99
-155/70 R13 Tyre on Steel Wheel - £14.99
-Bonnet Striker - £2.99
-12v Horn - £1.99
-Expansion Bottle Cap - 99p
-Radiator Hose - 99p
-OSF Seat Belt Anchorage - 99p
-NSF Seat Belt Anchorage - 99p
-Plastic Battery Tray - 99p
-Front Wiper Arm - 99p
-Front Wiper Blade - 99p
-Air Intake Hose (with clips) - 99p
-OSF Seat Trim 2pc - 99p
-Steering Column Upper Shroud - 99p
-Steering Column Lower Shroud - 99p
If anything doesn't sell it will be re-listed ASAP, also I'm adding more as I take it off the car.
Please have a browse though my items:
http://www.ebay.co.uk/sch/eam_enterprises/m.html?item=300664003296&viewitem=&sspagename=STRK%3AMESE%3AIT&_trksid=p4340.l2562
I'm breaking the whole car, but I'm keeping hold of the engine for now.
Things are selling VERY quickly! YES I DO end listing early on eBay to the current highest bidder (as per eBay's rules), so if you want something get your bid in early to make sure you get it.
If you are after anything that is not listed, please ask!
-12v Horn - £1.99
