Technical  Mk1 Uno electric window switch
UNO70SL
Hi guys,
I need to buy a new LHD driver side electric window switch since my old one has a broken frame and wont hold in the driver's door arm rest
This is my current switch:
https://imgur.com/jefCPPK
https://imgur.com/GhW6y7s
https://imgur.com/CMeIl1w
As you can see my frame is broken therefore it cant be attached to the arm rest. My switch slides from the side into the arm rest and isn't pushed from above as in later Uno MK2 models.
I want to buy a replacement one and searching ebay I find a lot of switches which none of them actually fits my car.
1. https://www.ebay.it/itm/PULSANTE-IN...048420?hash=item23b2a58964:g:j14AAOSwzfFd92aE mechanically it seems to fit because it has the frame with the edges which can slide into my arm rest but the elctrical connector is different than mine.
2. https://www.ebay.it/itm/PULSANTE-PU...746711?hash=item1c924f2d17:g:O~QAAOSwqXZZwL66 the connector seems to be like mine, but I don't see the frame which can slide into my arm rest, apparently it is for pushing it from above like in the MK2.
3. https://www.ebay.it/itm/181528680-F...398889?hash=item3b18a2e429:g:mM4AAOSw7U9bdFcR seems to fit, can slide and have the same connector only the wrong side.
4. https://www.ebay.it/itm/FIAT-UNO-AU...196630?hash=item23c282a2d6:g:gtoAAOSwiBBdQqtl correct connector but can't slide.
Anyway, as you can seen mine is somehow different than all the models available in ebay, how come? even though it says B569 on it I can't find the correct one.
I've searched Ansor catalog http://www.blufer.it/en/catalog-alzacristalli.html
And could not find anything that suits my car either they fit mechanically and have a different connector or correct connector but different mechanics.
Can you please help me finding the correct one?
Thanks in advance and happy new year :)
On my Mk2 switch, it is fairly easy to remove just the frame from the switch body and fit one from another switch. I assume this isn't possible on your switch? Sorry I can't suggest anything better.
Just to update:
I bought the MK2 switch (as seen on link no.2) and managed to fit it quite easily to mine.
Electrically it is the same connector as mine, and mechanically it slided into my arm rest.
