The MAP sensor is just to the right of the black plastic air filter cover, it should be under a triangular plastic cover. Remove the 2 screws from the plastic cover then you will see a pipe going from the MAP sensor to the inlet manifold. The MAP sensor is held on by 3 nuts, simple 5 minute job to change... Just wish I had spotted the split before changing the lambda and water sensor.
