Very low power, engine goes into crawl mode, I used ODB2 scanner to determine the fault codes, showing misfire on 1 and 4 cylinders. I was very very very careful changing cam belt, I used the proper locking toolkit. I was told I had set the engine on cylinder 180 out... I have taken the cam belt off again and I cant see anything wrong, it all lines up. Is this because I need to get the Multiecuscan to re-learn the camshaft position. (Is it still possible I set up the cam belt '180 degrees out' as I was told by a garage - how is that possible if I used the correct tools?)
