Does it happen when you adjust any of the 4 mirrors segments?Hi, the fuse (7,5) related to operativt the mirror keep blowing. I change it, adjust the mirror and seconds later, nothing. Where to start troubleshoot?
2018 Ducato 130hp
Yes it does.Does it happen when you adjust any of the 4 mirrors segments?
Assuming that the fise survives when mirror adjustment is not attempted, that would suggest that there is a problem with the common control lever,Yes it does.
Thanks, I will try replacing the controller and see. It could be as you said that it blows when I do certain movements.Assuming that the fise survives when mirror adjustment is not attempted, that would suggest that there is a problem with the common control lever,
Possibly the fuse will blow when horizontal or vertical movement is attempted but not both.
I suggest checking that the fuse only blows when particular movements are attempted.Thanks, I will try replacing the controller and see. It could be as you said that it blows when I do certain movements.
I will check that this weekendI suggest checking that the fuse only blows when particular movements are attempted.
Another possibility is that the connection that is common to 8 motors has an earth fault. This would cause the fuse to blow when one direction only, of movement for all 8 motors. Earth faults can occur when the door loom rubs against the body, and movement occurs when the door is opened or closed.
To save fuses when checking, I would be tempted to connect a 21W bulb in place of the fuse. However that is easier said than done.
