General Mifiring / Backfiring
Keiran02
Staines nr Heathrow
Hi My Brava 1.4sx Seem's To Have Developed Some Faults Are They Related????
Firstly It Seems To Developed A Misfire In The Wet, It's Happened Twice Now I've Taken The Leads Off Sprayed Them With Some WD40 And Put Them Back On And It Improves! Also I Think My Leads Might Be Cheap And C***!!!
Secondly My Exhaust Seems Loud However I Can't Find A Blow And I Get The Occasional Backfire When The Rev's Come Down! And Then Idles Erratically (I Was Told It Might Be The Coil????)
Also My Fuel Efficiency Seems Really Bad Approx 17-20 MPG????
Coor This Car Might Send Me Mad But Still I'm Liking My Fiat
replace plugs and leads first. coil failure results in running on 2 cylinders (very rough) so i doubt that is an issue.
did you check condition of the plugs too?
the exhaust noise is also an issue, a leak will cause uneven low back pressure which leads to rough running and scavenging which wastes fuel. you need to cehck the exhaust system carefully, the flexijoint is a favorite place to leak.
Hi The Plugs Were Ok (A Little White With Some Light Carbon Build up) I've Tried Blocking The End Of Exhaust And Spraying It With Leak Detector But Could'nt See Anything I Think I Might Just Take It To My Mate At ATS And See What He Say'a
Right After Spending An Hour Waiting At ATS I Got Bored And With My Washing Up Mixture I Found The Blow!!! Yay Even Better (I Think) It's The Joint Between The Manifold And Down Pipe! So Am Going To Attempt To Re-Seal It Tomorrow Any Pointer's????
