General Metal Pedal Covers
Vanders
Victoria
I really want to replace the default rubber accelerator and brake pedal with a fancy metal version for my Fiat 500X.
Problem is I can't find compatible ones anywhere!
I've had to return two sets due to being incompatible. First time was because the dealer accidentally ordered for a manual transmission, and the second time was simply because they wouldn't fit despite being designed for a Fiat 500X/Jeep Renegade.
The accelerator always fits fine but the brake pedal is always too small and has a rubber piece sticking out the back to slot into a hole that doesn't exist.
Anyone know some chrome covers that will fit?
Hi did you manage to find a compatible set of pedals?
I am also searching for my 500C , i like two codes : 59107083 +59107084
What about looking at the standard Fiat ones from the 1.3 DCT Sport? I dunno if you need the whole pedal or if the alloy pedal part is a stick/bolt-on job over a standard pedal... but I'd reckon there should be a few good condition pedals available from the breakers, if you need the whole thing.
Ralf S.
