Technical Marea remote key programming?
3awadallah
I have marea 2001 with 2 blue keys and a brown one
One of the blue keys doesn't work and i think it needs to be reprogrammed, but i don't have the 4 digits code , is there any way to reprogram it and get it work ?
Hi and welcome
If it has a MASTER key ( brown) it is also unlikely to have an OBD port under the dashboard
That is the early key security system..
Thank you,
It has 2 blue keys with single button at the side
And one brown without any buttons
One of the blue's is working as remote center locking and alarm activated
The other is not working , red lamp flash but the center doesn't respond
For ignition, for remote you would need the number.
Mine lost sync on the remote after one winter so I got aftermarket set with flip key and moved the ignition transponders to the new keys.
Red one has transponder molded in, no remote control in it.
No real way to get the code.
I just bought 25€ remote kit and 7€ fiat blanks for it. It installs under the rear seats as the control unit is there.
