jake_6_9 New member Joined Nov 24, 2007 Messages 98 Points 39 Location lincolnshire May 2, 2008 #1 a mates gonna sell me a set for about £40 which sounds like a bargain but i dont think it comes with any wiring, will i need any or can i just use my existing wiring from my originial headlights?? thanks
JoskeJTD Patron member Joined Mar 14, 2005 Messages 1,829 Points 422 May 2, 2008 #2 You can make your own. Just make sure all plugs and connectors are on the rear of the light. The rest you can make up for the sidelights.
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,763 Location Durham May 2, 2008 #3 the sidelight connectors from your original lights will work, but a bit of insulating tape is needed if you want to get a snug fit.
J jeffas New member Joined Dec 16, 2007 Messages 111 Points 27 May 3, 2008 #4 hi the pollys look much better than standard as i fitted them in my brava but i will say get better bulbs as i used the brava bulbs and they were crap
BRAVARulez Patron member Joined Mar 17, 2006 Messages 243 Points 126 Location Thessaloniki May 4, 2008 #5 I suggest you to replace the old bulbs with the Osram H1 NightBreakers...they do a very good job. Checj the link below for that bulbs. http://stores.ebay.co.uk/Power-Bulbs-Direct_H7_W0QQcolZ2QQdirZQ2d1QQfsubZ568959QQftidZ2QQtZkm
OP OP jake_6_9 New member Joined Nov 24, 2007 Messages 98 Points 39 Location lincolnshire May 4, 2008 #6 brill cheers guys hopefully ill get them now!!
Ozric-Al Established member Joined Aug 3, 2003 Messages 1,092 Points 208 Location Big-Les-Wade May 4, 2008 #7 Easy swap. Even I managed it with the help of guides found here: - http://www.fiatboo.co.uk/mod-a-bravo.htm#Marea
