Tuning  Marea 2.0 20V engine block swap
MareaHGT
Hello to everyone. I found a lot of threads about swapping 2.0 20V turbo engine from coupe into Bravos (it is the same procedure for Marea). According to eper, crankshaft is same in all 2.0 20V N/A and turbo versions, pistons and conrods are different. Cylinder heads are also different in N/A and turbo version.
Does everyone knows the exact differences between 20.20 V N/A (182B7.000 ) and 2.0 20VT(175A3.000) engine block itself?
Is it possible to swap everything from the 175A3.000 block (crank, conrods, pistons) into the 182B7.000 block, and fit the rest of parts(cylinder head etc) from the turbo engine?
Thank you.
Hello CFREITAS.
I know it is easier. And I know about oil turbo feed and case breather port difference on those two, not a big problem to solve - just interested if everything else fits on the 182B7.000.
the only problem with 5cyl engines is piston/cons and transmission, when going turbo. they handle no more than 300whp, but with forged internals they do 500+hp easily. Watch some brazilian Marea Turbos
