General marea 100sx td stuck in 2 gear help
eddie.forrester
Can someone help me.
Driving home from work and it kept jumping out of third into neutral.
Then when i went to revers it was juddering. It started to reverse and then stopped.
It is now as though it is stuck in 2 gears .When i let the clutch out it stalls.
The car is now stuck on my drive. can someon ehelp
i'm afraid it sounds like you need a new gearbox. :(
does the gearstick still feel the same as it always has and still feel as though it can select all 6 gears?
its defo gearbox failure then. a scrapyard box will cost approx £75. fitting will cost approx £100. unless milage is below 50k i would fit a new clutch while the box is off. a clutch will cost approx £50.
