Technical  Marea 1.6 poor power
rafy
Caracas
I have a Marea 1.6 with a problem of the power. I tried correct this failure replacing some sensor: Air temperature, Water temperature, MAP, TPS, and cleaned IAC and Injectors too replaced the Fuel Pump and spark and spark leads.
When I turn on the air conditioning the car loss very power, if I try start in a inclined street the car turn off.
I measured the coil resistance and the seconday resistance is 5.1 Kohm in both coils, is this correct?.
The car too have others problems, some times shake and I must brake or accelerate completly, is a car few smooth to run, for this cause the main bearing gearbox and the seal shaft was damaged.
When the car is cold and start have flat spots.
I need a orientation for this, please help me.
