ZapodeanuB
- Joined
- May 22, 2011
- Messages
- 2
- Points
- 1
Hello and I found I have a problem giving me trouble for a long time and I hope I can fix it with your help.
More precisely, MAP sensor, I May not know what to do to get rid of this error on a scan ...... FiatEcuScan P0105 gives me error that says invalid signal received from the sensor.
The hottest annoys me because of this error that I went off the engine.
It should be noted that from what I've seen this error only occurs in winter P0105 ..... the summer there's no problem
I cleaned the MAP sensor and plug that come with alcohol in it but the problem is not resolved. So what to do to get rid of this problem, if you change the MAP sensor will solve the problem?
Excuse Incoherent writing, use google translate
