Technical Lowering Springs??
Suffolk
Hey guys!
I would like to lower my stilo (1.4 3 door)
Any recommendation on brand?
Or how much i should lower it!?
Im thinking sort of Rear 50mm ish front 40mm ish!??
Also... Im really having trouble getting hold of any springs at all for a 1.4!! or am i being stupid and the 1.2 or 1.6 ones will fit!?
So any links and pictures would be great!
Thanks! (y)
Fletch!
Hey guys!
Thanks! (y)
Fletch!
Why not just wait for the springs to snap, car will be lower then:p
http://www.potn.co.uk/p1331655.htm
Your only choice really is Eibach (masses of threads if you use search).
Unless you intend to change dampers as well then don't drop lower than 30mm (unless you like crap handling (n))
That's interesting (y)
So you don't recommend ANY lowering springs without matching dampers then Morten?
You are right about that, Argon - I'd never do that.
I lowered the Uno I had for the first time about 5 years ago, with another brand of springs if I recall correctly. Handling was great for half a year. Then the dampers were shot like bicycle pumps. So, I would never lower a car without changing to sport shocks at the same time. I guess it is possible to mix and match to find great solutions, but the Eibach set seems pretty well balanced regarding enthusiastic handling and family comfort.
My Stilo got the complete Eibach set in march 07 and has been perfect since.
Morten.
Before
after
This is my 1.4 lowered 50mm on eibach springs
