Looks fantastic...
Q: Did the bouncy effect disappear?
I'm thinking of ditching the 30mm lowering springs and going for a proper coilover kit to sort out the damping mess. Also hopefully by summer when
Could always contact a reputable manufacturer of bushes and get them to make up a kit.No one seems to make a polybush kit yet. I suppose I could put it up on the hoist and measure all the existing ones up and see if I can order polybushes indiviudually. That seems a pain in the arse though. And no guarantee. Does eper show dimensions on bushes?
True but then again it is usually cheaper and easier to buy something off the shelf.I wanted some adjsutable lower wishbones for one of my race cars, nobody had them, so I designed & manufactured lower wishbones from Titanium. I was so pleased with the job that I then did some Ti front uprights & upper suspension arms.
Sometimes it's easier to make bits yourself.
Not to mention the "What is a control arm and what does it do?" postsIf I designed and manufactured suspension components for the 500 and fitted them I'd go deaf from all the cries of "OMG TEH WARRANTTY IS VOID!"
I checked the panda route and no luck. And others here have approached manufacturers and had no luck.
Not to mention the "What is a control arm and what does it do?" posts![]()
And anyway its a 500, we bought them because they are pretty!![]()
So the Panda uses different bushes does it? A bit strange really to do all that work to change parts for no good reason.
Well perhaps someone needs to have a look on ePER and see if the part numbers tally and also what other Fiats possibly use the same bushes. Like I said before it might be a lot more financially viable for someone to manufacture bushes. Just looking on the powerflex site the Cinquecento, Seicento, Punto and Uno share some or all of their bushes so it could be that the 500 and Panda use the same bushes already anywayNo, I mean I looked for Panda as well about a year ago and couldn't find any. I've not been underneath a Panda and mine at the same time to see if they're massively different. I shouldn't imagine so but then weirder things have been known to happen.
