Technical  Lower knee panel removal
Spyran
Greece
Hello everyone I recently bought a 2017 panda and found a device under the steering panel, after looking it up if found out it is a queclink gps tracker (probably from the used dealership). Anyway i removed the cables from the physical tracker but the wire are still there so i want to remove the panel under the steering wheel to get a closer look at whats happening but i dont see any screws but i also dont feel any clips.
So how to remove the panel under the steering wheel?
Model
1.3 JDT
Year
2017
My GUIDE.. Just click on my username
May help gain basic access
My panda was RHD (SINISTRA)
Yours will be LHD (DESTRA)
Does this help... ignore the subject of this older post (Haynes manual and a broken heater), but this post shows how to remove the panels:
https://www.fiatforum.com/threads/haynes-manual.482911/post-4556466
Yes it does thank you. Also i did a bit more digging and found a page on eLearn dedicated to removing it (referencing another post to remove the first trim to gain access to the screws). So that makes my post kinda useless but anyway this is the link.
