Technical Lower door hinge.
Migaard
Silkeborg
Hi Guys!
Another problem with my Marea.
The driver side (Left in DK) door is hanging a bit.
When i lift the door i see a lot of play on the lower door hinge, guess the pin is broken.
Is it possible to replace the pin only or do i need to replace the hinge?
How do i get access to the 2 allen bolts securing the hinge to the body?
Michael
I honestly have no idea if you can get the pin seperately - best just to ask the dealer. You probably can, I had to buy a new pin for the check strap - so I don't see why you can't for a door hinge.
To access the body allen bolts, you probably need to remove the wing... but I've not had to do it on a Marea so can't be sure.
Hope this helps. This is for the later Marea as you never stated what year your marea is.
Parts near the hinges vary between £0.66 - £11 depending on the part needed from Fiat.
Hi Guys, thanks for the replies.
Sorry forgot to mention it's a 1997 Marea, so it doesn't match the drawing
Can it really be true i need to remove the wing? That's quite a job isn't it?
Cheers Michael
