Technical  lower ball joint replacement - multipla
markiemark
Hi. Do you have to replace the whole wishbone for a lower ball joint replacement or can you just replace the ball joint? Cheers.
If I was you I'd replace the whole arm...too much hassle trying to do just the bush..
They are about £45 each fro s4p or even cheaper on ebay but not sure about quality!
My multipla failed today on bottom ball joints on both sides, a couple of years ago I replaced the bushes at the top of the wishbone because the ball joint was ok, now I've decided to get two new suspension arms from ebay £64.50 free delivery for the pair, not bad, I don't care what make they are as long as I get a year or two out of them, The car also failed on a track rod end and a rear shocker, all easy jobs and not too expensive.
