Hi guys
I need expert advice from anyone who can help me diagnose my problem im having with my 2002 fiat seicento sporting 1.1 mpi. I receive a low oil pressure warning momentary when its really hot outside and when been driving for a while. It happens when standing at a robot the light goes on and off intermidiatly and i sumtimes feel car almost stall when it happens. reving engine resolves issue. The engine has 141000km and im using 10w40 semi synthetic oil. oil was changed about 5 months ago and original fiat oil filter fitted.
Im thinking it might be faulty oil pressure switch or worn oil pump or just too hot. weather reaches 40 degrees or more when i get this problem. i change oil often and always use 10w40 of high quality. first problem im having with this car. had a fsh when bought 2nd hand.
If it is the pressure switch or oil pump i would really appreciate a guide where to find the switch or how to change pump. if its the spring valve relief is it part of the oil pump assembly? can it be fixed?
Thanks for always helpfull advice!
