Hi All
The Qubo continues to be a clown car:
Diesel Multijet 80K on the clock.
History:
Had a loose timing chain, replaced. New oil and filter change.
'Low oil pressure, stop engine' below 10K rpm and, sometimes, slowing for a junction/turning... but also cruising. Blip throttle and clears.
Checked pressure sensor - slight weep at the terminal.
Replaced sensor.
Hmmm...
Looked for leaks, none. Mechanical oil pressure test - fine, good pressure across the rev range. Multiscan connected, idling & cruising says so too.
But, on the outside chance - had checked it when the cover was off to do the chain and the cover was a bit scored but pump turned smoothly/felt OK - that the pump was broke, fitted new timing cover and so with it new oil pump and stop/start valve that come on this model.
Had pro mech re-set the ECU with Snapon kit. No warning
... for a day
Various discussions with local tuning specialist who replaced the injectors (one over-fueling) a month or so before, and industry mate who specialises in rebuilding these motors consensus was, given all that had been done, likely ECU fault.
As no one has ECU testing for this particular vehicle (!), sourced replacement (used) and cloned. 2 days driving all good
Today
:bang::bang:
Help/thoughts gratefully received.
eg.
Anyone know what pin on the ECU the sensor links to - thinking might be a damaged sensor wire?
Do I just drive it until the motor cracks and diagnose that way
Is there a way to turn off the alarm?
Thanks All
History:
Replaced sensor.
Hmmm...
Today
:bang::bang:
eg.
Thanks All
