Right, just got back from college and tested my sensor with a warm engine. I let the fan cut in then turned off the engine and tested it, it read 0.23.
I'm not sure where the 315 has come from, I'm getting confused about how you convert a 20k reading to a 2000k one I think its best if we only use the 20k setting.
So my readings are:
Cold 4.80
Hot 0.23
And your readings are:
Cold 5.90
Hot 0.28
Doesn't seem like my sensor is too far out really so maybe it isn't the problem. How would we go about testing the voltage? The sensor will need to be plugged in for us to do that so where would we connect the mulitmeter into?
As for the thermostat I reckon it might well be stuck open, carboard over the rad hasnt made much difference, temp is probably a little bit higher now but not much. Heater does take a while to get hot aswell. I'll get a new one and fit it at the weekend, it could do with a coolant change anyway, suppose I might aswell change the sensor at the same time, will completely rule it out then.
So my readings are:
Cold 4.80
Hot 0.23
Cold 5.90
Hot 0.28
