ludicrouslarry
I have had power problems with my Multipla. It is noticable in higher gears as it limits my top speed and causes a lot of downshifting on medium sized hills on the highway. I sit there with gas pedal floored without power. In fact I can pump the gas pedal in the top 2/3rds of it movement with no change in power (no surge in power or engine RPM). Generally need a VERY flat space or downhill to get the engine >3000-3100 RPM. I can get there easily by down shifting--- but no power. I do not have the problem that most people say comes with the dirty EGR valve. In fact, I have less smoke than I had before.
The STRANGE thing is that I can sometimes overcome this problem. If I am on an upward grade and have the rpm around ~3000 RPM with the gas pedal fully pressed (the pedal to the medal= as the saying goes) it might fix itself--- I get a noticeable surge in power and the RPMs climb. As long as I keep the gas on I can climb through the gears with this normal powered engine. I can keep the power by keeping the RPMs >3000 if I do not need to upshift or go faster. However, if I am behind a car and have to slow down (take the foot off of the gas), I once again have an underpowered engine. The procedure described above to get the engine to break free does not always work (in fact, it seems to be getting harder and harder to get it to work).
Does anyone have any thoughts on the cause? It should not be the fuel injectors, because I run a deisel injector cleaner additive with every tank. I have also changed out the fuel filter, but that made no difference.
