Technical  low brake fluid warning
nikkiy9
Rallying Crazy guy
Newcastle
hey guys, I'm getting the low brake fluid warning YET, I'm just below the max marker, as it was topped up last week when I done the clutch, any ideas if it has a fluid level sensor?
the car is a jtd 115
There will be a fluid level sensor, it's probably stuck in the reservoir somehow or has a leak & has become heavy... take a look at the reservoir...
well, replaced the brake fluid reservoir and I'm still getting the warning (brand new part from fiat)
it only came on after I tried to access the ABS with FES on my mates laptop
That may have been useful information for anyone trying to help... before you spent money. So the laptop was being used to look at an ABS fault, & the warning didnt come on until u connected the laptop?
warning came up after he had left (car didn't give fault while he was still connected) but it didn't allow us to access the abs either
just tried to connect again using his FES, i'm connecting using the green adapter, selecting bosch ABS 5.7 ASR/TC (which i scanned first to make sure i connected to correct item) and it shows in the bottom left corner connecting, then all of a sudden it changes to disconnected and i've no access,
the last thing i'm gonna try is a computer reset tonight, (hopefully that might fix the blooming fault)
