WildFeraligatr
Hi gang
I recently replaced the lower rear dog bone engine mount on my 500. I had to remove the middle exhaust pipe off the catalytic converter to actually get to the bolts, so I've refit that too.
Since doing all this, there's been a really loud knocking/rattling coming from under the car when driving around. I lifted it up and found the exhaust had slipped back - so I refit it and the same thing happened again. Did it again and did the U-bolt clamp up REALLY tight, left it overnight for the threadlocker and exhaust paste to settle, and it's still doing it. I've not jacked up the car yet to have another look because I'm also having issues with my Panda and frankly I'm a bit knackered today.
One thing I did notice is that there are slots running up the pipe of the cat, which, since replacing the engine mount, the exhaust no longer fits over. I've sanded it down, checked for blockages on the inside of the pipe, but it just won't budge any further up.
The engine mount bolts are torqued to spec (130nm to the body and 80nm to the gearbox) so I don't think this is the issue.
Any advice would be appreciated, but I suspect where the engine mount was very loose before, that either gave me more clearance to get the pipe onto the cat - or I just did it before I reconnected the rear muffler so I had more clearance there.
Posting this in case I've missed something completely stupid and obvious, or if anyone has done this before and can give any advice
