Technical  Loose wire in trunk, electrical problems
tempra16
So if i put reverse gear, two warning lights lit that says there's problem with brakelights. But there really isn't and all lamps work normally when putting reverse gear and I've changed new bulbs also but no help. Looked at the trunk there is one cutted white-blue loose wire but no idea from where is it?
Another problem that maybe related is that if I turn on to the right and blinker is on when pressing brake, blinking slows down a bit. Also dashboard's yellow fog-light is blinking along with green blinking light.
