Technical Long clutch travel
Cardiff
The clutch pedal (2002 1.2 model) travels nearly all the way down before there's any action, and it's getting harder to change gear. The pedal doesn't return home either without a bit of help.
What sort of adjustment should I ask for at the garage?
Thanks.
Yes.. sounds like the clutch cylinder is leaking fluid (either internally past its seals, or you may also see an external leak).
I hope it's an external one (metal "sausage" sized cylinder on top of the gearbox) on the 1.2. It's an easy swap if it's external.
If you have an internal (bell-housing) cylinder then it's a gearbox-off job and spectacularly more expensive as a result. In this case, I'd fit a new clutch and release bearing at the same time, so that you won't have to touch it again for a very long time.
Ralf S.
