Linux and pptpd - Geeky Stuff!
mehstg
GPS Multijet 1.9 Orange
North London
Hey guys
Just messing about on my little debian server and I have decided to set up a VPN to get into my home network from my laptop.
I understand that PPTP probably isn't as secure as Ipsec, but the bigger overheads on ipsec make it a no-no as it will be slower. (I could be totally mis-informed here, maybe someone could shed some light on this also)
Any ideas how to get pptpd to bridge to my eth0 connection, as my router handles all DHCP. I have this set up and working on my Win7 box at the moment, but I would like to move it to the Linux server as i keep that on 24/7.
No idea about the PPTP issue, but IpSec probably won't be noticably slower for you, as you're not talking about tens or hundreds of Mbps. Even on older hardware it can do several Mbps with virtually no CPU usage.
At least that's my experience.
What spec is the linux box you're tunneling to? I've only ever used checkpoint/cisco/juniper for ipsec vpn's but if its just you connecting to your own network I'd be surprised if you maxed out the box. The tunnel set up and keying takes a bit of cpu but that's not gonna max out a box. As long as you keep the settings sensible I can't see ipsec being a problem. And it's generally speaking a better idea. Check out FreeS/wan. It's box incredibly flexible and a royal pain in the arse to setup. But it does stuff checkpoint wants thousands of pounds to do :)
Cheers guys
I didn't mean overheads as in maxing the box out. I was under the impression that the encapsulation around Ipsec was larger, thus making it a slower connection. Correct me if I am talking out of my arse!!
I am open to suggestions on other ways to achieve my goal though. I was messing about with hamachi, but couldn't get that working either!!
P
Hey guys
Is your Linux box not multi-homed? (bit insecure if it's not :()
I'd put everything on Linux and just use your router as a simple gateway but make sure it passes everything to the ext. nic (by convention eth1).
If you'd prefer to have PPTP preconfigured then you could always install SME Server which is a dedicated server disto (there's no desktop front end so be prepared for remote access :))
