Hi
Took the 500 out on Sunday - first drive since timing belt/tensioner/water pump change, other than the drive home from the garage
Drove for about 4 miles and car going really well - got on the motorway and up to speed without issues (70-75 mph)
Then the "Stop Start Disconnect" warning flashed up and the engine management light was on - the car lost power and started popping and banging. Managed to exit the motorway with very little power from the engine. Had to stop for some lights and the car would not pull off - no power what so ever. Popped hazards on and turned engine off, restarted engine and no warning lights and car drove normally back home.
Left it running on the driveway for 15-20 mins without any issues, albeit when blipped the throttle, it would not go over 4000rpm.
Car is 5 years old and only has 9000 odd miles
I assume the stop start warning is a red herring - but clearly the engine management/loss of power is a worry. Initially i was concerned the timing belt was not fitted correctly, but car ran okay once it was restarted - the only other thing i can think of is a TDC or Crankshaft sensor, which may have been removed when the belts/tensioner was fitted? And i wonder if the lack of rpm above 4k is some sort of Limp home mode that reduces power?
Car is booked in for investigation but anyone any other suggestions to the cause
Fingers crossed i can make the 10 miles to the garage !
