Technical  Light relay - where is it ?
ToreH
Norway.
Hi
I've got a Marea Weekend 1,6 98 and have lost the righthand dipped beam light. Bulb, fuse and grounding is Ok. Must be the relay. Where have they hidden the relays ???
ToreH
The relay is beside the fuse box situated under the dashboard. However check the junction unit & the stalk unit wiring continuity as well.
subija
Hi subija
Thanks for your help so far. It was not the relay. I now measure 9V on the lead for the lamp, but it won't glow (it's new). Looks like a connector with a high resistance that will give some voltage but not any current that can give any effect to the lamp ?? Where do I find these connectors ?
ToreH
The dipped beam relay is below the instrument panel. The dipped beam relay is used for both (right & left). If this relay is faulty, both will not ON. But for your case...Check the condition of the fuse at the junction unit, check the bulb holder, check the front light cluster, check continuity of grey cable, or restore the continuity the green color cable between the junction unit & right front cluster.
Good Luck
subija
