Technical  Light fault
Quinn01
Hi All,
Looking for some suggestions on an electical problem !
I own a Marea Weekender 1.6 petrol, Yr 2002.
Most lights will not function, parking lights, dims, instrument lights are not coming on.
However cabin lights, brake lights, indicators are functioning normally.
I have checked fuses , all seem OK !
What should I try next ?
If the exterior lights (side lights, head lights and instrument lights which are all on the same circuit) are not working and there is power to the fuses and they are really ok (check with a test lamp on the non-live side of the fuse as I have seen fuses which look fine but are blown) then it sounds as if you have a faulty light switch.
