General lhd clutch cable
BR65
The clutch cable on my left hand drive Panda (l993) has snapped and the covering that surrounds it and which it is threaded through is broken also. My garage are unable to source a replacement..does anyone know where I might be able to obtain one?
The car is from 93 so I assume it has servo assisted brakes, then you need to check if the cable is secured to the mounting point with small m6 bolt, because there were also types without this bolt, only secured by twisting it to position.
Chances are, that you need 575mm cable used between 1991 and 2000. Like this one:
http://allegro.pl/show_item.php?item=5582956987
Thank you so much for the link - I will show it to the guy in the garage.
