Technical  Lexia access code
FRANTIC FRAN
After yellowfish's struggle with retro fitting the electric doors, and not to be outdone i had a go at retro fitting headlight washers to one of my many Ulysses in the yard.
Replaced everything from the donor, including fuses. The plug for the high pressure water pump was already on the loom so no wire splicing needed.
Now into Lexia to turn it to "present" on the bsi to find this too needed the access code to alter it. Was about to give up as like Clicky said and I had thought the code was specific to each VIN and I wasn't going to pay fiat for it as it is a scrapper.
At this point I thought "what the hell" try my code for my own Prestigio that I already had and bingo it worked on the other car.
The code is 03114 so try it on your own before you hand over your hard earned cash to Stoneacre (assuming they know it anyhow!)
This code is only really of use to anyone who is going to retro fit any optional extras over from a donor eurovan2 or pair up new tyre pressure sensors.
The Code Is generic solely to lexia 3 software.
It is {as I have Found out} nothing to do with the VIN of the Vehicle.
the code is 'if you like' a password protection to prevent any 'accidental' changes to BSI.
If you are asked for the code it is because {apparently} there could be serious damage done to the BSI and other Nodes!
