Technical Length of wheel Bolt
Hi all,
Dragging out this old thread as it contains some of the info I'm looking for.
I've picked up a v. cheap set of 2.0 GT alloys (4 big fat spokes and centre caps) to throw onto my 1.4ie.
I was going to use the bolts that used to hold lancia delta alloys to my old strada.
However, these are 60mm total length compared to the 40mm standard steel wheel bolts, and although they fit fine on the fronts the ends of the bolts foul the return springs in the brake drums at the rear. :(
So as it looks like I need 8 new bolts - should I go for the 50mm or 55mm described by sedicirich?
Does anyone know which is correct for these particular wheels?
or I guess I could put on a small spacer on the rears.... any thoughts?
Alternatively, if anyone wants to swap a full set of the correct size for my 60mm set?
As ever thanks in advance for your invaluable help.
Palicus
