General Left Hand Front Lights
integrale
Osnabruck
Anyone have any left hand front lights that they don't want? Moving to Germany so require a set. Have my local garage looking also...
I do take it they are all the same fitments?!
Cheers Tim
Are these polyelipticals?
If so - flip the beamstops inside and you're done.
Yes they are, ok thick time where is the beamstops?????? Will have a look thou see if I can see...
as for the beam deflectors you can't use them always, the TUV test will not allow..
Thanks for your replys anyhow:D
Tim
Look for my description on how to open the lamps in an oven and dismantle them. Beamstops are inside the projectors. Look inside them (turned off) and you'll see them inside.
Once you open everything you need to flip the metal plate visible on the picture from slash / to backslash \
Ok thanks for that much appreciated, it's in with my garage at mo so will mention them in the morning. (Integrale specialist):)
It will be better than the £160 each lamp like what FIAT wants...:mad:
Cheers Tim
Hi, I moved to Munich (Munich) 2 years ago and converted my (polyeliptical) marea to german spec and did the tuev (German MOT).
I bought the lamps on ebay.de (about 120euros all in for the pair)
They are not original fiat (DEPO), but fitted easily as replacements for the RHD ones.
If you need any help with the paperwork etc that you need for the TUEV and registering it in germany, let me know.
