General  Leaking Seicento Sporting
andersoj
Water is leaking into drivers footwell.Have pulled carpets back but cannot see where water is coming from.Have ran hose over windscreen , sunroof and vents in front of windscreen but did not leak. Next day came out after period of rain and drivers foowell was saturated.Car sits facing down the way on a sloping drivway.This leaking of water only recently started after a minor rear end collision.Dont know if this a coincidence.Any advice would be appreciated.
John.
Sounds daft, but it could just be the rear light clusters. Water can flow in through these and track across the floorpan inside.
Failing that, Seis do sometimes leak from badly masticked seams around the battery tray in the engine bay.
custard boy said:
well not really a guide :rolleyes:
have you checked your coolant levels?if it started after a rear end bump have you lifted the boot carpets? also check aroyund the rear window seals
Definetly not coolant levels.Not lifted boot carpets yet but they are dry.Think rear window seals are a good starting point.Cheers
John.
Cheers for that.Will check those out this weekend and let you know how I get on.
John
My Cinq had a similar leak, like Pete suggested the water can run the full length of the car, the clusters need to be re-fitted carefully to ensure a water tight seal.
Liam
