Technical leaking injector 1.3 mjet 90
limpyjet
Portsmouth
Hi all,
my 1.3 90 mjet punto has a leaking injector. its got quite bad recently so i would like to change it asap. i was wondering if anyone knew the official part number for the seal. the injector is working fine, i believe its just the seal that needs replacing.
ill take it to my local garage to get the work done, but ill buy the part separately as i can get it cheaper.
is there anything i need to be aware of before starting this?
many thanks
cam
Hi all,
many thanks
cam
Apologies as nit sure if part but curious to know how you knew you had a leading injector. What made you think you had this problem
around the injector there is a big build up of carbon. You could also hear a clicking noise coming from the engine.
easiest way to check is to remove air box and check for any residue around the injector. i can post mine last if you wish? although mine is really bad
Thanks for that I would really appreciate it
Hi all,
many thanks
cam
Hi. :)
Use ePER to get the FIAT parts diagrams ;)
"ticking noise" ?? I know people who will like this... if they had a diesel engine.
and BTW, here's the parts drawing & #...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
