magijamarko
- Joined
- Jun 27, 2005
- Messages
- 121
- Points
- 43
Hi guys...(and the occasional girl)
I have quite a big problem with my 95 Cinq Sporting..
As my expansion bottle was porous(the material was so tired, i was able to scratch it out with my fingernail..) i changed it with the fancy Seicento one - the one with the blue cap, white, and with the small hose conecting on the upper right side (looking from the front of the car..). :idea: I got the air out of the sistem (bleed screw on rad, bleed screw on firewall..) and thought -YESS!!
It fitted perfectly..looks good, and i do not need to worry about coolant leaking out of the porous plastic...
But..the car started to DRINK coolant. And that big time..
So after pouring in a lot, i started to investigate..and found..:
As the sistem presurises (slowly..temp rises, goes slowly to 75..), water starts pouring out at the pipe(steam and all..) from engine to heater matrix (i think there are 3 pipes there..). Apart from being fiddly to get there, i think that it shouldnt be difficult to fix..Undo, reconect, new washers..is that ok..?
Ok..i thought..ill fix that over the weekend (read - my girlfriends dad fixes it over the weekend )
But this morning..i went to inwestigate some more..and found a trickle of water from above the oil filter..and..it seams it originates..between the block and head...Is that even posible..??Could it be the washer on the metal pipe on the cooling sistem-the one in front of the engine..??
So now i need help..How to fix this stuf..? is the expansion bottle the reason (wrong kind??) or is it just that the old one didn't hold its pressure, and the fault was already there, only smaller as the pressure didn't rise??
Water pump was changed in august, as was the cambelt and bearing..so..i think that can't be the reason.. so..any sugestions..without ripping the engine out?? :bang:
Thanx..as its my only car..
Greatings
Marko
Greatings
Marko
