leak in roof
leak in roof
J
Jon
hi
I have a bRavo HLX and when it rains hard there seems to be aslight leak inbetween the widscreen and the roof panel. Water leaks when I go round a bend sharp and can leak at either end. any possible solutions?
Jon
Sorry John, would this also explain extra loud wind noise when driving on Motorways?
Re: Re: leak in roof
I don't actually have a sunroof in my Bravo so can't really say on that one but I is probably the case.
I only know what I've read from some of the others who have had the seal changed.
John.
Re: Re: Re: leak in roof
yes it would easy way to check.....
Slide open the sunroof cover if it gets worse you know its time for a new seal, £15 from fiat and easy to do - instructions on the bravo guide. If it still leeks then could be the aerial mounting base!
Sunroof seal
Si
I have looked for the instuctions for the £15 sunroof seal but cannot find it. can you direct me to the exact place.
Cheers mate
Re: Sunroof seal
£15 is the cost for the new seal from fiat the bravo guide has the instructions on how to change it
Re: Re: Sunroof seal
Sy
Call me stupid but I cannot find the instructions on how to change the £15 sunroof seal. I have looked in the how to fix section but for the life of me I cannot see how to change it.
Billy
Re: Re: Re: Sunroof seal
http://www.bravo-guide.co.uk/fix-a-bravo about 3/4 way down
Removing The Sunroof
If your car is gettig wet inside and all the other tips havent worked, this excellent write up from J Moore is the last resort.
Work Slowly and Carefully
Removing the headlining is the first job to tackle. The plastic covers on the front, middle, and back pillars need to be removed. The front just pull and pop off. The middle ones have to have the seat belt holder guide removed before you can unscrew the single screw and pop it off. The rear pillar is similar, the seat belt guide holder has to be removed, then the 4 screws holding it on before poping it off. You also need to remove the sun visors, and grab handles inside. Popping off the grab handle covers is awkward at first. With a thin screwdriver you can ease them off. The plastic covers on the seat belt guide bolt is best removed pushing up and out from the bottom of the cover.
At the back, the headlining is held with two plastic bungs to the roof. just pull them out. Of course the interior light has to be dropped out too. Plus the sunroof motor.
Now its a case of easing the rubber sealing strip back slightly to free the headlining.
Once its all free, take it out through the boot.
Test the sunroof at this stage, to find out where the water is coming in. Poured water onto the closed sunroof, and then look inside the car for evidence.
To take the sunroof out, first open it so that it had slid to the back out of the way. You need to take off all the nuts attaching it to the car roof body, and the 4 supporting brackets at the back. Do the ones at the back last, as this is where the weight is (thats why you moved the glass back there remember !). Don't forget to free the drainage pipes off the sunroof. You will need help now, as the sunroof is heavy, and you need someone to help support the roof while you undo the last nuts. With your friend, back the free sunroof out the boot carefully.
Best have some clear place to put it before you take it out though.
In the factory they seal 4 plastic sections to the metal sunroof runners. Each of these plastic sections has a drain point. If they didn't do the work correctly, then any one of these sections could leak. Clean the joining edges as best as possible, then used a screwdriver to "paint" silicon sealant into any joint area you feel isn't sealed between the plastic and metal.
Then it was a case of re-assembly in reverse. Provided you didn't move the sunroof glass after taking the motor out, it will still be aligned when you bolt it back together.
Before putting the headliner back in, wait for the sealant to totaly dry and then re-test pouring water on the sunroof. If its still coming in, at least you only have to take the sun roof out again !
It takes longer to put it all togethed again. The door seals are a pain, as you have to get the plastic pillar covers behind the edge of it. Lots of fiddling to do there.
It takes about 1:30 hours to get to the point of releasing the sunroof. About 2 hours examining and sealing the sunroof, then about a futher 3 hours getting it all back together again. A days work really.
Re: Re: Re: Re: Sunroof seal
Thanks Wimmy I have read that, however it does not describe how to change the sunroof seal which is available from Fiat for £15. That is what I am refering to and I cannot find the instructions on how to change it.
Cheers
Billy
Re: Re: Re: Re: Re: Re: Sunroof seal
This is an easy one.
Think of the sunroof having a gutter on it going all the way round.
The seal is pressesd down into the gutter. Its not glued on. To get it off:
1. Open sunroof 1/2 way so it goes within the roof
2. Find where the ends of the seal meet.
3. From outside you'll be wanting to get your fingers under the seal. Grab it from inside the car and your pulling out, to outside.
4. Its not glued on, the seal has a metal frame inside which can be tight around the sunroof. I was firm but it came off.
5. Clean up any rust and paint over, then refit the seal, you may need to cut part of the seal off as mine was slightly long.
Hope this helps.
Joske
Re: Re: Re: Re: Re: Re: Re: Sunroof seal
Joske
Thanks for the info.
A quick question though. How did you remove the seal from the sunroof with it half way inside the roof and did it make a difference once changed?
Billy
J
1
1K
Frank
F
S
1
7K
Streak2013
S
M
2
755
Dark Lurker
P
1
472
Dark Lurker
